- happybooker1ExplorerI found them today! They should really help. Thanks again!
- wbrown62ExplorerI don't remember what department in Wal-Mart had the register covers. Seems like it was home accessories. Not all WM may have them. Good luck.
- happybooker1ExplorerGuys thanks for all the ideas. Looks like I might be searching my nearest Walmart!
- wbrown62ExplorerI found small magnetic covers at WalMart the correct size that stick to the registers. They were made specifically for this type situation. They're even printed to look like registers. Keeps stuff from falling in and are easy on the feet as well. If we use the furnace, they are extremely easy to remove.
- old_guyExploreryou can cut screen material to put in the floor registers to keep stuff from falling thru.
- Old-BiscuitExplorer IIIWell we did 2 things.......after I stepped on one and busted it we purchased better quality thick laser cut registers that can be closed
AND cut to fit some magnetic sign material to place over them when not in use. The signage was white so GF used some craft paint to do a design on them that matched carpet color - korbeExplorerWe weren't used to them at first but now they're just part of the environment.
- loulou57ExplorerYou could replace them with either wood or plastic from a box store. You can close the vents when not in use.
- Home_SkilletExplorer IIThose magnetic signs you see on truck doors work well. Just cut to fit.
About RV Newbies
4,032 PostsLatest Activity: May 10, 2013
