docsouce's avatar
docsouce
Feb 11, 2023
1/2 Inch Drive Corded or Battery Impact Wrench
Primary use would be to change a flat tire when I'm on the road. If I get a corded wrench I would need to start the generator to use it. I would also need an extension cord. If I get a battery operated wrench all I need to do is make sure the battery is charged. Corded Pros: less expensive, takes up less room and I think it would more powerful than a battery operated gun. Cons: need to have the generator running to use. Battery: Pros: ready for immediate use. Cons: takes up a little more storage space, must be charged to use, cost more and this is just a guess, doesn't have the same power as a corded gun. My current set up is a 3ft length of 1 1/2 pipe and a 3/4 inch breaker bar which will work fine but I'd like to simplify my approach.
As always your opinions are valued.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 15, 2025
