SpencerRB wrote:
Check out the Puma 12v compressor. About $200 on ebay. Blows away anything in the price range, including the Viairs.
Absolutely.
I have a Viair 400P. And I've worn out several of the MV50's. The MV50's put out about the same amount of air and similar tire fill times to the Viair, but for a lot less money. But, the Viair is still going strong and several MV50's have given up the ghost.
I also have the Puma. It's larger, takes up more space and uses more amps than the Viair or MV50, but absolutely blows those other compressors out of the water for air output. And it reeks quality. I had mine mounted under the hood of my Jeep for a couple years where it was exposed to every which kind of nasty conditions and it has never skipped a beat. Hands down best bang for the buck in 12V compressors there is, IMO.
But, I have since replaced the Puma with one of
these. An ARB twin compressor unit. It is even more impressive than the Puma. But at over $500, it better be. And, while I like it very much, like it more than the Puma, I don't like it $300 more than the Puma.
Money no object, get the ARB. Money matters at all, get the Puma. The Viair is a good solid, dependable unit. But the MV50 performs about equally for a fraction of the cost. The MV50 doesn't last very long under severe duty such as I subject my onboard air compressors to, but for occasional tire filling use, you may well have one last you forever.
Just my opinions, based on extensive use of the above...
- Coyote
