ftoledoaz's avatar
ftoledoaz
2013 tacoma
I have 2013 , 4x4 manual tranny, toyota tacoma, access cab. Can I tow it with a dolly. I know I can't tow it four down. Not sure if I can use a dolly and if I need any addition to it like a tranny pump. thanks
  • Didn't the OP put this in the dinghy forum... or did you change it for him?
  • No, you can't unless you disconnect the rear u-joint.
  • check your owner's manual under either "towing behind a motorhome" or "recreational towing".
    that is the best source. doesn't much matter if a third party says yes, if the book sez no.
    bumpy
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
