bagman's avatar
bagman
2018 Chevy Sonic Front Wheel Drive...
Can we tow our Chevy Sonic? I'm thinking that we are NOT towing a heavy car. I'm thinking of a new 29' Class C with the new FORD V-8 engine and using a tow dolly made from Aluminum. Any advice will be greatly appreciated. Thanks in advance, Chuck "The Bagman!"
  • Nice to hear from you Bagman. It has been a long time since I read anything from you. chevman retired from rving
  • If you use a tow dolly, I would suggest a couple things.
    Get one with brakes. Surge brakes saves installation of wiring and brake controller in MH.
    If possible, get a small hitch for Sonic to enable you to move dolly around.
  • Not sure the exact nature of the question, but yes you can tow a Chevy Sonic on a dolly, some models can be towed 4 down. If you’re concerned about weights, the combo of a dolly and sonic (unless loaded with rocks) should be well below your max tow numbers.
    I had a 2013 Sonic w/automatic and towed it 4 down. Good car. Newer ones have more electronics and such so consult your manual on the exact procedures required to tow it.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Feb 05, 2025
