dmitch91950's avatar
dmitch91950
2019 Toyota RAV4 FWD
My Question about my 2019 Toyota RAV4 FWD, What special thing need to be done to the car before it can towed on a dolly. I know how to release the electronic brake, is there any thing else?
Thanks
Danny
  • Thanks for the help, The 2019 Toyota RAV4 Key-less ignition and has electronic/Electric brake, and I found a YouTube video from a Toyota dealer in South Carolina, that was posted showing on how to turn off the Electronic brake
    Thanks
    Danny
  • I have been towing a 2006 RAV4 FWD (FRONT Wheel Drive) for several years on a Master Tow dolly with swivel pan. Simply drive on dolly, put in PARK, remove key (locks steering) tie down with straps and go. I do not have 'auto brake' on the RAV4, but if it requires the doors be closed to deactivate, then make sure the doors are closed and you're set to go.
    If you use a dolly without the swivel pan, the steering must be unlocked.
  • I haven't driven a 2019 Rav-4, but...
    Generic warning for cars with electronic parking brakes: Many of them automatically engage when the driver-door is opened, to prevent rollaways if the driver forget to place the transmission in park.
  • To echo what's been said REMCO Towing says
    AWD - Must be towed using a trailer
    FWD - Must be towed on a tow dolly. Please confirm in owner's manual.
    They don't give any REMCO options.
  • That manual is nuts!!! It shows with 2wd you can tow behind an RV with the rear on a dolly and the front on the ground on page 193.
    Then on page 194 it says to not tow an AWD with any wheels on the ground, yet they show a pic with an "RV" using a dolly with the rear end on it and the front wheels on the ground with NO red circle???
    So what is it? Go to page 615 about the "emergency" section and they show and say different things???
    So, yes, I would have no idea what to do either? Been looking at the **** manual for 15 minutes now and still can't figure it out!
    In the end, I'd just not figure on being about to tow a RAV4 with any wheels on the ground...
    My wife has a 2003 RAV4 4wd and the manual (which is only 271 pages total) clearly shows that you can't tow it with any wheels on the ground..
    Good luck!
    Mitch
  • You aren't kidding, the owners manual is over 700 pages!!!
    Not sure if by FWD you mean 4WD or Front WD?
    FWIW, the same question was sent to eTrailer: Link for FWD. I would contact them regarding 4WD.
    OK, I'm really bored so I looked and finally found it on page 615!!
    Quote:
    2WD models
    Be sure to transport the vehicle
    with the front wheels raised or
    with all four wheels raised off the
    ground.
    AWD models
    ground. If the vehicle is towed
    with the tires contacting the
    ground, the drivetrain or related
    parts may be damaged...
    Scott
  • I tried looking in my daughter's owners manual. Not very user friendly!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
