TC285
Sep 08, 2020Explorer
2020 Escape Hybrid Towing Question
Some questions on towing a 2020 Ford Escape Hybrid AWD - behind my Motorhome. I have an appointment to have the car set up towing in a couple of weeks and there are a couple of questions I would like some help with.
When reading through the procedure as stated on Page 282 in manual to set up Neutral Tow some questions come to mind.
1. The last step states “Switch the ignition off” - (set up is done in accessory mode prior to this last step).
2. Is the 12 volt power socket active during Neutral Tow mode or does it remain off because the ignition switch was turned off during set up for neutral tow ? I plan to use my Brake Buddy which requires the 12 volt power socket.
3. With ignition switch off does this have any affect on steering wheel movement as it tracks behind the motorhome?
4. Has anyone used the Brake Buddy with their new Escape Hybrid?
Thanks
Thanks
