- fj12ryderExplorer IIII assume that you're referring to commercial semi's?
- RCMAN46ExplorerThe more pin weight the better provided the TV can handle the weight.
The big boys have pin weights that approach 40%. - mkirschNomad IIWell, I've looked at several 5th wheels with dual 3,500lb axles, and GVWRs of 8000-9000lbs...
Not even going to address the guy who used the actual weight of his trailer... - fj12ryderExplorer III
eHoefler wrote:
Ya think?
Take the GVWR and subtract the AWR from it, this is how much the manufacture expects to be carried by the tow vehicle.
Let's see: I have 3 6,800 lb. rated axles, and my GVWR is 18,000 lbs. OMIGAWD I have a minus amount to be carried by the tow vehicle. :) - justafordguyExplorer
I guess it depends on the manufacturer, mine has 14k of axles and weighs 14,215lbs loaded.;) - eHoeflerExplorer IITake the GVWR and subtract the AWR from it, this is how much the manufacture expects to be carried by the tow vehicle.
- IvylogExplorer IIIThey hande so well because the pin is over the rear axle and they have twice as much pin weight as necessary so they can use cheaper axles and tires. Yes I had a 5er with two dual sports on the back.
- JIMNLINExplorer IIIIndustry says 15-25 percent.
20 percent would be a good average to play with.
I've ran GN and 5th wheel trailers with 17 percent on up to a full 25 percent hitch weight. - irishtom29ExplorerThank you.
- mdamerellExplorer20-25% mine runs about 22%
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
