BigSur2's avatar
BigSur2
AC and Fridge Vent Question
Is it okay for me to blast water....and/or air under and around the ac vents in the attempt to clean and remove debris? How am I supposed to know if there are potential leaks without removing the vent covers?
  • Well the OP said AC vents so not sure what covers he's referring to. Anyway a garden hose, not a pressure washer, shouldn't be a problem. If you can drive down the freeway at 60+ mph in the rain with no leaks a garden hose shouldn't cause a leak.
  • Sounds like you-all are talking about two different things.
    Vent "covers" usually means the Maxx-Air or Camco covers that are like sea shells sorta things installed over the vents so the vents can be left open in the rain.
    I think the OP is talking about the vents themselves; the square devices mounted on the roof with a hinged lid.
    Vent covers install with external bolts and brackets. Vents have a flange that is screwed to the roof and covered with sealant.
  • SoundGuy wrote:
    I suppose it depends on your definition of "blast". :R I just finished washing the roof on my own rig and although I did "blast" under the A/C and vent cover with a garden hose I sure wouldn't do that with a power washer. :E
    Take 'em off if you're concerned, there's only four bolts holding each one in place.
    Are the bolts covered with lap sealant?
    Sorry for the late reply
