jkbrea's avatar
jkbrea
AC fan
I have an 05 Thor Jazz. I have rarely used my AC. It blasts cold air just fine. Now I noticed that after a couple hours it is barely blowing out air. I shut it off for awhile and then it will be fine for another couple hours. Is this normal?
  • Thank you so much. I'll get on it and post back what it was.
  • Make sure the filter is clean. the coils are clean and the evaporator is clean. Dust/dirt build up can create freeze ups easily. Don't overlook the possibility of low Freon after this long.
  • The evaporator is freezing up. Yes, like a big chunk of ice, and that does not allow the air to pass very well. Check to make sure the freeze probe is correctly installed into the evaporator fins. The unit should be cycling the compressor on and off to control the formation of ice on the fins.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
