Jul-04-2017 09:05 PM
Jul-05-2017 04:43 AM
DiskDoctr wrote:
Get the hottest air out first, provide cooler air to the A/C to further cool, and reduce any inside pressure by allowing a good exhaust while you replace that air with ever cooler air.
Jul-05-2017 12:51 AM
yillb wrote:MrWizard wrote:
he said the 15amp shore power and his solar are supplying charge to his 'Lithium battery bank
he is running the a/c from inverter power
I assume,, he has a deficit during the day using more power from batteries than is generated, and gets the batteries fully charged overnight ?
He's running TWO ac's from the inverter. I don't think it matters how many batteries you have, that's a lot of power. I'm pretty sure he's not even running the compressor, and it's just the fan as someone else pointed out. It happens on our venom toyhauler all the time.
Jul-05-2017 12:34 AM
time2roll wrote:
The real solution is to pull 50 amp power to the RV.
Otherwise the air just recirculates so the vent fan may concentrate cool air in one area but in the end is pulling heat in somewhere else. RVs are generally not well sealed. If you have a hot box from driving all day it may help to push some of the hottest air out. Soon you need to just close up and let it work.
Jul-05-2017 12:29 AM
MrWizard wrote:
week ago sunday, it 109F here
and we are expecting triple digits latter part of this week
today was 95F
with a 3400w generator and 109f, i can only run (1) of my (2) a/c units
but with a little shade i can keep it about 85f in the front halve of the RV
leaving the rear on blower, and various fans going
for a nap, i will switch the front a/c to blower and turn the bedroom on cold
shade cloth over the RV might help as will pulling in the slides
yeah some RV's leave no room too move around when you pull in slides
still it something to 'think' about, might help you be a little cooler
during those triple digit days
Jul-04-2017 11:35 PM
Jul-04-2017 11:17 PM
Jul-04-2017 11:10 PM
Jul-04-2017 10:56 PM
yillb wrote:
For two, if that is happening, you're likely causing damage, they had to replace the unit because it burnt out the compressor, trying to run 2 ac units on so little power seems to be an expensive problem, at least with the venom they own. I'm not sure how you're turning 15A into enough starting amps, let alone running amps to power nearly 30 amps worth of AC units. If' im not mistaken, two of the three you have are 15k units, they take quite a bit to start, and just a little less to run, that's not including all the others you're using. Though, they don't have solar, so I can't speak to that.
Jul-04-2017 10:09 PM
Jul-04-2017 09:58 PM
Jul-04-2017 09:55 PM
rvexodus wrote:
Curious, has anyone else experienced this effect?
Jul-04-2017 09:47 PM
