Old-Biscuit
Jun 25, 2017Explorer III
You have the standard SW6D water heater
(Suburban Water 6 gal Direct spark)
No real good reason to replace that water heater.......just fix it
The t-stats (under that rubber cover just above the gas valve) are good....otherwise the spark electrode would not even fire/CLICK.
Bad t-stats...no DC
The control module is OK cause DC is getting to spark electrode (CLICK) and gas valve (Flame lights)
The spark electrode is OK..it fires/CLICK
What is not OK is the 'signal that proves' flame is lit is NOT getting back to circuit board so it does it's 3 tries and then 'locks out'
When flame lights off a milivolt signal is generated (flame ionization/rectification)
That milivolt sgnal uses the spark electrode as return path to circuit board
Being milivolt it doesn't take much resistance to stop the signal:
* Dirty/sooted/carbon spark electrode
* Dirty/loose high voltage wire connections (orange wire for spark electrode
* Bad ground.....spark electrode assembly mounting bracket screw ---needs to be clean/tight
* Cracked ceramic insulator on spark electrode...signal goes to ground
* Spark electrode NOT positioned properly----needs to be 'engulfed' in flame (glows red)
In other words.sounds like you just need to clean/position or MAYBE replace the spark electrode.
BEFORE spending $$$
Suburban 232258
Bad t-stats...no DC
BEFORE spending $$$
Suburban 232258
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
