Kamcoman
Apr 01, 2006Explorer
To remove most wheel seals, you do not need a seal puller at all. Drive out the inner bearing with a brass punch by going in through the outer bearing hole. There should be small recesses that you can place the punch tip into so the punch only rests on the outer race of the inner bearing. This does not damage the rollers or the cage. Just drive the inner bearing out and the seal will come with it. This usually doesn't damage the seal at all.
Keith
Keith
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
