Hammerboy's avatar
Hammerboy
Another tire question
I've been searching the forumns but can't quite find what I am looking for as far as tires for my unit.
Our fifth wheel we purchased this past spring wieghs in just under 9k dry, has a gvwr a shade under 12k and a pin wieght of around 1500 pounds. These are published wieghts as I have not taken it to the scales yet for real world weight.
In all the years of owning a rv, I never had much concern or any trouble for that matter with the stock st tires they came with. We never took any really long trips either. Our unit has 15" aluminum rims with the dreaded Towmax tires. So my question is what tires would you put on? Would you move to 16" rims for better choices and Craigslist the old ones? Are all st tires rated for 65mph? My unit not a heavy beast like a lot of you guys pull so I'm not sure if I should go to lt tires or stick with st's.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
