Trails_And_Tail's avatar
Aug 25, 2015
Are aftermarket tachometers reliable?
I want to install a tachometer on my 91 Class C with an EFI Ford 460 power plant. Are they at all accurate and reliable?
  • bgum wrote:
    Some are some are not. You get what you pay for.
    X2, there are good ones and there are bad ones.
  • go to Summit Racing... dot com.... a good one is worth the money..
    size is another matter. LOL.
    Anything you get will be more accurate than what you have now ;)
    And if it was slightly inaccurate, will you be even know????
  • Electronic tacometers just measure pules. Pretty simple device. You should be able to check calibration with a signal generator.
  • Don't know if that year supports an OBDI, but if it does, look at a scan guage. You can get the tach function plus about 20 others.
  • Some are some are not. You get what you pay for.
  • I have two in separate older vehicles and I have never had a single issue with mine. I too like knowing how many rev's my engine is making. Both were straight forward and easy to hook up, using a lead off the coil and selecting how many cylinders on the tach it self. Most come with good instructions and I hooked mine up so even the dash lights would turn on the back light in the tach. All the best, Hans
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
