โJun-03-2021 08:28 PM
โJun-05-2021 05:27 AM
dedmiston wrote:
Yeah. That was a weird comment. LEDs aren't even that bright and you're just replacing what you already have.
A buddy I camp with (boondocking) has that LED strip right beneath his awning. He installed it in just the right spot so that it lights up his awning if it's deployed or casts some light on the ground if the awning is in.
Most of us just turn on our porch lights at night and he has his red LED strip. It makes it easy to navigate around camp without stumbling and without killing your night vision.
If Flyboy is camped so close to you that your LEDs kill his view of the stars, then he's breaking the unwritten code and camping way too close to you. He shouldn't be able to see much of your lights or hear your music. Sounds like he's close enough to smell you though. Not right.
โJun-04-2021 11:17 AM
dedmiston wrote:He's entitled to his comments/concerns/gripes. He does have a legitimate gripe. Mine are screaming drunks, neighbors trying to burn rotten firewood, loud trucks and playing cornhole until 2am.
โJun-04-2021 08:21 AM
2112 wrote:
LMAO
Don't worry Flyboy. We are pedestal hopping, full hookup, glampers. We are travelers, not camping anywhere you may be stargazing.
Let's make a deal. I promise I'll keep my lights to a minimum if you do the same with your nasty campfire smoke. Deal? :W
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โJun-04-2021 08:09 AM
#1Flyboy wrote:LMAO
Please reconsider exterior lighting! With many folks lighting up the campground weโre losing the camping experience of watching for shooting stars, satellites & planets. Then with the use of lighting, TVโs, stereos, etc the generators are coming on disturbing another camping experience - the quiet not found in the cities from which the campers cameโฆ or maybe Iโm wrong but I thought that camping was to get away from all that stuff?
โJun-04-2021 07:54 AM
GDS-3950BH wrote:RECPRO may be a winner. These are IP68 marine grade compliance.
A company named Recpro on Ebay sells a kit that is IP68 outdoor rated for about $50. The LED strip is encased in a waterproof silicone sleeve. The kit comes with plastic channels you attach to underside of the awning rail with included 3M tape, then the LED strip snaps into this channel. They make it this way as 3m tape will not stick to the silicone sleeve. The bad side is if you cut it to length you compromise the silicone encasement, but its available in different lengths. It is alsobonly sold in white or blue so you can't make the campground look like the Vegas strip of thats your thing.
โJun-04-2021 07:31 AM
2012Coleman wrote:dodge guy wrote:Looks interesting - but says Waterproof and for indoor use only. Wondering how they have held up under the RV - still sticking?
I bought these for my MH.
LED light strip
They make a complete kit with power supply and remote. I put these on the awning rail at the wall and under the RV. Have had them for 3 years now and another set on our TT for 5 years.
โJun-04-2021 05:29 AM
LED light strip
โJun-04-2021 05:22 AM
โJun-04-2021 05:05 AM
โJun-04-2021 04:52 AM
โJun-04-2021 03:56 AM
mleekamp wrote:I've seen a few installs where they used the porch light power. Remove the porch bulb, tap into that power and use the porch light switch to control the LED strip. May work for you if the porch light is conveniently located.
Our Class C did not have them originally, so I'd have to drill a small hole thru in order to get power for them. I just haven't had the desire to drill that hole yet.
Point is, there are waterproof/outdoor versions on amazon. Costs more.I am looking for something reliable. My original awning strip failed within 6 months. They were replaced under warranty. After 8 years, my current strip are more than half failed.
โJun-04-2021 03:47 AM
Ron3rd wrote:Thanks Ron
I ordered mine off Amazon. They come on a roll and install with 3m double sided tape. Very easy. I'll post more info tomorrow. They can be cut to length with scissors BTW
โJun-04-2021 03:28 AM
โJun-04-2021 12:38 AM
