wa8yxm
Apr 09, 2019Explorer III
travelnutz wrote:
So glad I didn't go to 6 volt GC batteries as when one fails you lose the use of 2 as it takes two 6 volt batteries to make 12 volts. so easy to find which is the failed 12 volt battery and just disconnect it!
FIrst 9 1/2 years is .. well the average is 7-10 and the record is not far beyond that so 9 1/2 is rather good.
As for the 6 Volt GC.. "When one fails" you need to re-think
Each PAIR of GC-2 is ONE 12 volt battery. When one half of a 12 volt battery fails. Yes you replace both halves.. But always remember when you are carrying them they are six volt. when on teh shelf they are six volt. when you hook up that jumper lead they became two halves of a SINGLE 12 volt battery and that is how you treat them
IN your case (six group 31's) That's 2 pair and a group 31 on the side. BUT.. All in all. I would not expect longer (or shorter) life.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
