Bob_Vaughn's avatar
Bob_Vaughn
Bedroom slide cover
I think the spring on my bedroom slide is too tight. When the slide starts out I have to push the top to get it to go out parallel with the bottom. If so is it possible to loosen the spring?
  • Sometimes the slide awning springs are too tight and does cause this to happen. Dealers can adjust the spring tightness.
  • Could be the slide room is not correctly positioned in the opening and dragging at the top. If the room has wood trim then check carefully for signs of water intrusion causing the wood trim to swell. Hopefully it just needs repositioning.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
