akaPedro's avatar
akaPedro
Best approach for more LP into our RV...?
This is not something I will do on my own...I will hire a licensed contractor.
Our motor home is in a shed about 60 feet from our house/500 gallon LP tank. We don't use this tank as it only hooks up to our pool heater.
Motor home has a 24 gallon tank.
In the event of a serious, long term, hacked power grid outage, we would like to move into the m/h. 24 gallon tank won't last but a month or so in the winter. I will assume no electricity means no propane refill at a gas station or elsewhere.
We have a gasoline generator and 2000w inverter/charger. I would like to a)...buy two $500.00 LP tanks, hook together outside the RV shed and pipe inside. Or b)...hook into our 500 gallon tank, trench over to the RV shed and pipe inside.
As I understand, it is not possible to fill our 24 gallon tank from our 500 gallon tank...and so it will be hooked up some way directly into the RV stove, furnace lines.
Sound reasonable...any better ideas ?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
