down_home
Feb 20, 2019Explorer II
I think I see where you are going on this. A larger tank. heck with the manufacturer and see if they offered a larger tank on that chassis.
Tanks weight quite a bit full and it could change balance left to right.
Ours is 36 gallon maybe larger, I don't remember exactly right now.
Your compartment might handle the size but if what it is mounted like Winnebago of a few years back a piece of plywood hanging in the open behind the compartment door, You will need to find a good RV tech to engineer good solid mount. I don't know about carrying a full and very heavy separate tank in a compartment rolling around, to be connected by hose when you stop.
