Technically, the issue is that the black tank system relies on the fluids to carry the solids away in a rush when the tank is full and the valve is opened. If the valve stays open all the time, there is not enough liquids flowing fast enough to carry the solids away and they will build up in a pyramid-shaped pile directly beneath the toilet drop tube. This quickly dries into a horrible stenchy mass that will tax your best efforts to dislodge it. Water is your friend with an RV toilet. It really helps to fill the toilet bowl (by half-activating the flush lever/pedal) and then flushing that down after each use of the toilet. This will help break up the just-deposited waste and make it more able to be washed away when the dumping occurs. It's best to always wait until you have at least half a tank of black water before dumping as the volume of water is what helps the solids to be flushed out of the tank. When out with our RV, my schedule is dump grey water each day, the black tank every 3rd day. I'm assuming you know the drill to dump the black tank first then the grey tank to flush the worst stuff from the fittings and hose.
