johnhicks wrote:
You'll need the Roadmaster 9160 system plus appropriate seat-mounting bracket, lighting kit, umbilicals, tow bar, baseplate etc.
The 9160 is the car-end part of the Brakemaster, which you use since you already have the compressor. If you can, confirm that the compressor and proportioning valve actually do work before buying more.
I think John made a typo when recommending the 9160 braking kit. I believe he's referring to the 98160 "second vehicle kit with breakaway for BrakeMaster systems"
The kit is available from e trailer for $399.00
http://www.etrailer.com/Accessories-and-Parts/Roadmaster/RM-98160.html
The 9160 kit is a complete system for motorhomes with air or air over hydraulic braking systems.
The complete system for a gas powered motorhome is the 9060, which includes the compressor, proportioning valve and all the other parts installed in the motorhome which you already have.
We've had the 9060 system in 2 motorhomes and have been completely satisfied with their performance and longevity. The first was in our 2001 Winnebago Adventurer. We installed it with 20,000 miles on the odometer when we changed from pulling a Buick LeSabre on a dolly to pulling a Jeep TJ 4 down.
We had about 112,000 miles on the motorhome when we traded it in for our current 2013 Adventurer. We bought a "Second Motorhome Kit" (98300) for the new motorhome. We're still using the car portion of the original kit since we're still pulling the same Jeep. We have about 32,000 miles on the motorhome portion of the system in our new motorhome, and over 120,000 miles on the equipment in the Jeep.
