Inmans's avatar
Inmans
Broken plastic wire support on slides
The plastic strip that supports some wires under two of our slide outs has broken. Has anyone had this happen, and if you did, how did you fix the problem. The replacement parts seem expensive, and look like the same problem would happen again very quickly.
  • Thank you, we will see what we can do. We do appreciate your reply.:)
  • Have replaced two of the three on my fiver. 6 years seems like a decent life spwn to me. There are alternatives, but there going to cost you about 4 times more than what is on there. If it is broke near one end simply cut if and reattach using some small screws
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
