- bjkb1fExplorerIf you know how to use basic hand tools and follow instructions, you can do it. I installed one having no prior knowledge of how to do it. It took me 45 minutes or so, but it got done.
As a previous poster said, you likely will do better than most dealers. I sold the camper I installed the hitch on and bought a new one. Had the dealer install it since I was already there. It looked level when they pulled it around, but then once I got to see it on an actual level surface, it clearly isn't, so I will have to adjust it. Yes, they installed it, but it isn't properly adjusted. I'l wait to do this until we get most of our gear in it.
I wouldn't blink at installing one again. - drsteveExplorer
BarneyS wrote:
mbopp wrote:
I had to re-do the installation on our last TT after the dealer messed it up.
Not uncommon at all. That is why I made this post quite a few years ago to help members get their hitch set up correctly. Before that, I used to e-mail members a Word copy of it when asked.
You have to realize that most of the techs who set up the hitches at a dealer are not RVers themselves and most likely have never actually towed a travel trailer on the highway. They usually set up a hitch the same way for every trailer that goes out the door regardless of what the instructions say. Also, the setup for a new, empty trailer are quite different from one that is ready to go camping in.
Barney
The last hitch I bought was also the first ever set up by a dealer. It was done by a kid who probably shaves once a week (whether he needs to or not), and he nailed it. I use a bit more bar tension with a full load, and it's perfect. Yes, I was amazed. - BarneySNomad
Barney - mboppExplorerI had to re-do the installation on our last TT after the dealer messed it up.
- ppineExplorer IIISure. Follow the steps. You can fine tune it with some trial and error.
- whiteeye42Explorerif you can read instruction you can do it it is not that hard
- drsteveExplorerAs others have said, the hitch comes with instructions, YouTube is full of vids, and it's a straightforward operation. Go for it. Not only will you save a few bucks, you'll learn how your hitch works.
- jfkmkExplorer II
Iraqvet05 wrote:
It can be a DIY project but you may need some uncommon tools. In the case of the Equal-i-zer, a 1-7/8" thin wall socket and 320 lb torque wrench are recommended to install the ball.
If you’re at all handy, it is an easy install with the exception of this. I was fortunate when I did my install in that I was able to bring the hitch head to work where they had a big a$$ torque wrench. - LwiddisNomad IIII (Mr. All Thumbs) did it...therefore anyone can.
- wnjjExplorer IIThe sticky thread at the top of this forum has a lot of info. https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/17730894.cfm
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: Oct 05, 2015
