Carrying a Motorcycle on a DP
lj2654
I am interested in getting a Harley Davidson motorcycle to haul behind my DP. Do they make a carrier that mounts above the towbar so you can flat tow your car and a bike. Not going to be a big bike, probably 5-6 hundred #'s.
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
12 REPLIES 12
Ivylog
I'm amazed that someone who has been on here since 2000 has not weighed his coach. How much pressure do you run in your tires? I guess you do not want to know how much you weigh.
Upgraded with a 08 HR Navigator 45โ€™...
Bill1374
Ivylog,
I haven't weighed the coach so I can't give you the axle weight. My guess would be that the bike and lift together would be in the neighborhood of 1050 pounds.
KZ Montego Bay in Florida
Rockwood lite up north
2016 HD Street Glide, 12 Fatboy for cruisin
Ivylog
The OP's 2001 Beaver is before DP's started to gain weight so my educated answer is he will have enough rear axle reserve. This is based on my putting 1500 lbs on the back of my 1998 Beaver... click on "how I tow" in my first post above.
tinner12002
I seen a couple of trailers on ebay someone had for sale that was made to haul a motorcycle and a car as you would on a tow dolly. The bike sat across the trailer and then the car was on the dolly.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
We_Cant_Wait
For the most part about the only DP's that can handle the additional weight of the motorcycle on the rear lift that you want to do is a DP with a TAG Axle to handle the extra weight.
Ivylog
I would be interested in the axle weights above?
Rarely on the rear of a DP do you need more than 100 psi in the tires so 400 more pounds per tire should not be a problem.
Bill1374
Running an Overbilt lift on my PHAETON. It handles my StreetGlide just fine but I started with a 10k towing capacity. The SG runs right on 800 pounds and the Overbilt has the optional bracket for a towbar. The only thing I have noticed is a slight rear end push on a curvy road.
cooper841
Mighty Hauler
Dana Cooper
Chipper(Lab)
2007 Fleetwood Fiesta LX
2003 Harley Fatboy mighty hauler lift
2010 Kia Soul
hypoxia
Ivylog wrote:
The lift and bike are going to put 1400 lbs on your rear axle and take 500 off the front. Do have that much reserve on your rear axle?
And perhaps more important than the axle is the tire limit.:h
Jim
2007 Monaco Signature Noble III ISX 600HP
Triker33
For Rear Lifts have your front & rear axle weighted when loaded for travel. Then you can add on the extra weight of a lift by below.
Measure the distance from the center of rear axle to the center of the weight(Lift)
Divide that number by the RVโ€™s wheelbase.
Multiply the result by 100 to get percent.
That percent of the load is added to the load and becomes the total load added to the rear axle.
That percent of the load is subtracted from the front axle weight and unloads the front axle by that amount.
800 lb bike, Lift 100 lb=900 lb
Center axle to rear 120โ€ wheelbase 240โ€
120 divide by 240=0.50 X 100= 50%
Weight is 1350 lb added to rear axle
Front axle will be 450 lbs lighter
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
Ivylog
harley-dave
There are 2 that come to mind right off. The Hydra-lift and one from Cruiser-lift. I've seen both in the world and they definitely work.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
