- 3_tonsExplorer III
wapiticountry wrote:
time2roll wrote:
EV charging at 240 volts continuously draw approximately 32 amps. Typical RV loops are seven 50 amp pedestals with a 200 amp main. They are designed and constructed under the demand factors for RV usage set out by the National Electrical Code(NEC). Two EVs charging on a loop consume more than 30% of the available power before an RV draws a single amp. It is not a boogie man it is a physics and mathematical fact. Of course we don’t have reams of real world experiences with mains overloading because we could do our research and add. In the real world 2 plus 2 still equals 4 and using 30% of a power circuit’s available power will materially effect the ability of that circuit to supply additional power to the other items on that circuit. The purpose and mission of our parks was to provide the necessary services for the RV. Not the incidental items or vehicles they might bring with them. EV charging, in our opinion ( the only opinion that mattered) was EV charging could compromise that mission.PButler96 wrote:
Yes and the real world experience does not describe any actual electrical issues.
Real world experience from a former campground owner and not a lot of hot air blown out of an Rvnet resident experts arse? That's a refreshing breeze.
Like chasing the boogie man at 2am.
Still should respect the owners demand and go somewhere else next time.
Thanks for pointing out that ‘Facts Matter’ adding to what some might think should be merely intuitive…Call me late to the party :Z, (lol-!!), but I’m now starting to see through the Grift :S ($$)…
3 tons 3 tons wrote:
Yes I agree the campground should impose an additional fee of maybe $30 to $50. I would recommend $50 the first night and $25 each subsequent night. Larger RVs with larger batteries could be more. The convenience to the camper should bring profit to the campground.
I don’t own an EV, but it’s been reported that charging an EV can often cost $30-40 dollars (please correct me if I’m wrong)…To some (count me out…), subsides ROCK!!…I get it - But is it ok for this added expense to be absorbed by the CG’s owner??…Enquiring Minds would much appreciate a rational answer - please advise…
3 tons
Probably should restrict charging times also. Or limit to L1 plugged into the RV exterior outlet.- wapiticountryExplorer
Still should respect the owners demand and go somewhere else next time. - 3_tonsExplorer IIII don’t own an EV, but it’s been reported that charging an EV can often cost $30-40 dollars (please correct me if I’m wrong)…To some (count me out…), subsides ROCK!!…I get it - But is it ok for this added expense to be absorbed by the CG’s owner??…Enquiring Minds would much appreciate a rational answer - please advise…
3 tons - PButler96Explorer
Perhaps because the campground owner anticipated the electrical issue before it occurred, and put measures in place to prevent the issue from cropping up, which is called being proactive BTW. PButler96 wrote:
Still should respect the owners demand and go somewhere else next time.- 3_tonsExplorer III
NamMedevac 70 wrote:
At some point campground owners will give up the ghost and chuck it if these outrageous demands on them continue for ever more power for electric sucking RVs and EVs. Expecting them to invest in expensive rewiring underground wires, pedestals is a form of arr
Of course, some will but many won't. I almost feel pity for the mom and pop owners but like other mom and pop business owners they are being squeezed out by the chain business and some of them are now losing profit due to consumer reduced demand due to new round of inflation. Happy camping to the egg
Before we sold and got the heck out of dealing with the public we had a firm no EV charging policy. Had more than a few EV zealots argue on and on why they should be allowed to charge. Usually had to end the conversation with mom’s tried and true “because I said so”.
Even though we made it abundantly clear to every guest with an EV that charging wasn’t allowed we would have a few that though they could sneak it in under the cover of darkness. But they didn’t realize we had nightly security patrols. When security saw an EV being charged their orders were to alert me or the on-site manager. We took great pleasure in waking the occupants at 2am and informing they they were to immediately disconnect and if they did it again leave immediately.
As others have pointed out, EV draw power on a much different demand cycle than RVs. They are not compatible with the electrical loops that are designed for RV usage. We were not willing to risk having entire loops of RV pedestals going down because a couple of EVs charging continuously created additional demand that tripped the main breakers.
BINGO!!…. ‘Unless advised otherwise’, site pedestals were not designed to be repurposed for EV charging - but shouldn’t prioritizing RV’s just be common sense?? (not so much!)…
I’m sticking with my prediction, when the air conditioners crash, ‘something wicked this way comes’ :E…
3 tons - FishermanExplorerPart of the issue is that campgrounds were set up for camping and not charging EV's at whatever rate they use. Maybe campgrounds sould charge an extra $50 for that and slowly improve the wiring.
- Grit_dogNavigator
dedmiston wrote:
time2roll wrote:
3 tons wrote:
Actually the heat wave is upon us right now today. Plenty of reserves in CA. Feel free to plug in.
Maybe the real question is, when the heat wave hits, should CG pedestals be repurposed for charging EV’s??… Like it or not this will surely be the position of some affected others…Just saying…
3 tons
Although still best to conserve from 4 to 9 pm. However there will be NO enforcement.
No enforcement, but how did you like your latest Edison bill? Ours was 3x last years, but our usage was slightly down.
There are no free lunches.
Ouch! As in now being charged $.30-.50 per kWh? - PButler96Explorer
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
