- RognBonExplorer
Posted By: full-timer on 02/03/16 05:08pm
I buy the Duck brand A/C filters at Walmart for $1.00 enough to cut and fit for three filters
Same here. With as inexpensive as they are, I never even considered cleaning it. - down_homeExplorer IIThe reason it appears that lint is stuck on the filter is because of grease.
it nd dust are stuck on it. It tries to roll up if you should try to wipe it.
To prevent it we seldom cook with oil in the coach certainly t high temperatures. water vapor in whatever is being deep fried and the grease combine to coat everything. We put paper towels over the stove vent on the convection/microwave above the stove and splatter screen on top of the pot or skillet and turn the vent fan on, nearest kitchen. It sometimes suffers a build up and I have to take it apart to get the screen out to clean it. Some newer ones the vent screen pops out without having to take whatevr I have to take off to get to the screen. Don't have to do it often enough so that I remember what.
Just throw away the filter and cut a piece from the cheapies at WaL Mart.
Just make sure the filter media is thick enough and the stiffer he better. The edges of the plastic trim hold it in place.
They also have some with carbon something or other in them. I don't know if they would restrict airflow too much or not, given that on low settings, in high humidity some ACs freeze up. - full-timerExplorerI buy the Duck brand A/C filters at Walmart for $1.00 enough to cut and fit for three filters
- ken56ExplorerAir flow is essential to efficiency for these air conditioners so keep it clean. The filter in the picture is way too dirty. I also just buy the cut to fit material and replace mine with new one at the beginning and at mid season. when you start seeing dirt collecting on it its time to replace it. It doesn't take much to slow the air.
- AllworthExplorer IIWipe it with a dryer sheet before reinstalling it. Cut down on the "static cling".
Seriously; it helps. - tvman44ExplorerWallyworld.
- prichardsonExplorerBrush it off first with an old hair brush or vegetable brush then wash.
- coolmom42Explorer IIWash it often. Use a small amount of dish detergent in the water and rinse thoroughly. This will disperse the stuff that sticks to it. Replace as needed.
- Dutch_12078Explorer III buy the cut to size material as well. Even Walmart usually has it.
- NanciLExplorer IIYou are not doing anything wrong.
We do ours the same way, but after it dries, just use a fairly stiff bristle brush to go over it to get the remaining lint off.
Just make sure you don't tear it with the brush.
Jack L
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
