Cherguin's avatar
Cherguin
Jan 05, 2024
Coachman Mirada 35KB engine cover cup holders
Has anyone found a good solution to the shallow and useless cup holders built into the fog house of the Mirada?
  • I can not remember what size, but this works great for me. Its a pvc pipe reducing coupler. The small end fits great into the cup holder and the larger end holds larger cups, bottle water etc. Any of the big box home stores should have it.
    • Cherguin's avatar
      Cherguin
      Thank you for the suggestion.  I tried the PVC reducer coupling but couldn’t find any that would come close to fitting.  Was your cup holder made like the one pictured below?
  • You could get a GPS holder if you needed a location. Otherwise, you could put extra tire caps used to fill tires with air. I usually loose a few when filling tires.    ðŸ™ƒ
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Jan 31, 2025
