way-lou's avatar
way-lou
coating the roof
Hi Every
We just bough a 1998 class c should I recoat the roof the roof look great now, there's so much talk about coating the roof I was just wondering what to do if anything
Thank You
Wayne
  • It seems all of the manufacturers recommend keeping the roof membrane clean using mild soap and a soft brush, but no coatings are recommended. About 10 years ago, I had my rubber roof coated with a non-petroleum based rubber coating made for that purpose. The coach is now 20 years old and the roof is in great shape and has never leaked. So, I don't know if my preventive measure was significant in prolonging longevity or I'm just plain lucky.
    I'm anticipating having the roof re-coated here in the near future just as a precautionary measure.
  • IF it leaks then it may be worth putting a coating on. With proper care (which usually means doing as little as possible to it) they usually last 20 years or so.
  • We have a 96 Southwind with the original roof. It's in great shape. I'll coat the roof at some point if I still have the same RV.
    At this point it doesn't need coating.
    Seal your seams or any questionable areas with Eternabond.
    Dicor self leveling caulk also does a good job.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
