Cold in the bedroom.
swimmer_spe
2023 cherokee wolf pup 22bp
The heat is wonderful.... and not.
It has 2 outlets on either side of the kitchen cabinets. The problem is, with the door closed to the bedroom or bathroom, they get really cold. The doors have a bout a 2 inch gap at the top and bottom.
What do you do to get better heat in the various rooms?
39 REPLIES 39
swimmer_spe
pianotuna wrote:
swimmer_spe wrote:
pianotuna wrote:
Add a large grill in each door.
I was thinking of doing that. How big did you do? Did it work?
I did it for my pantry for the exact opposite reason. I wanted it to stay cool. There is one grill at the bottom and another at the top.
Bigger is better.
Consider electric heated carpets from Tempurtech.
https://www.tempurtechmanufacturingllc.com/
Problem with the heated carpet is that I tend to be on battery power for the coldest times. So, anything electric is not a good option.
spoon059
Drive someplace warmer...
2015 Ram CTD
2015 Jayco 29QBS
pianotuna
Nomad III
Nomad III
Bigger is better.
Regards, Don
swimmer_spe
dedmiston wrote:
swimmer_spe wrote:
dedmiston wrote:
#1Flyboy wrote:
โ€ฆโ€ฆ. A good down comforter and then you can turn the heat OFFโ€ฆโ€ฆ..
And then your pipes freeze.
By the time that is a risk, the lines are winterized.
Then you arenโ€™t camping long enough. :B
You mentioned you donโ€™t have enough room for a buddy heater. We have about a foot on either side of the bed and 18โ€ to 24โ€ at the foot. Itโ€™s not spacious, but thereโ€™s room for a heater and two dogs.
There is about a foot on the sides and end of the bed.
I mean I am camping with winterized lines. I tend to store it near the end of November.
dedmiston
Moderator
Moderator
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
swimmer_spe
swimmer_spe
MitchF150 wrote:
It seems strange that the bedroom does not have it's own vent?
On my rig, with the front bedroom, middle living/kitchen, rear bath, the bath is the only 'room' that does not have it's own vent because of where the entry door for the rig is..
I only have 2 vents. One in the middle and one to the bedroom.
Normally, I don't like to run the gas furnace as it's loud and uses a ton of gas.. I always have at least power hookup at the sites I go to, so we have a small electric heater that I'll use in the living area. When the door to the bedroom is closed, no heat really gets in, but usually the comforter and shared body heat is fine..
We close the bedroom door because all the LED lights that stay on makes in the living area makes it really bright in that room. So much so, you don't need any lights on when going to the bathroom in the middle of the night.
Anyway, is there anyway you can add a furnace vent to the bedroom? I know when I use ours, it really heats it up nice.. It's just loud when running.. My furnance has about 4 unused 'cutouts' that can be used for additional vents. It really blasts the air with only 2 of them being used!
Good luck! Mitch
No way to vent it to the bedroom.
This time of year, it will be used in the bush without much power outside of the battery and possibly a generator.
swimmer_spe
Mayor30 wrote:
If you can close the vents in the living room kitchen area, you can force more heat back to the bedroom.
There are no vents in the bedroom to begin with. I would need to put something over a vent.
swimmer_spe
swimmer_spe
dedmiston wrote:
We put a little buddy heater in the bedroom with us.
I really don't want to do that. There isn't much floor space.
MitchF150
Good luck! Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Grit_dog
Navigator
Navigator
Youโ€™re assuming itโ€™s ducted to the bedroom. It is very likely not.
But anyway this is one of those questions that makes a person wonder how some people actually function in normal day to day challengesโ€ฆ
Grit_dog
Navigator
Navigator
swimmer_spe wrote:
QCMan wrote:
Keep the doors open.
I am trying to avoid that.
Lol
dedmiston
Moderator
Moderator
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Deb_and_Ed_M
Assuming there's some sort of a nightstand, a small electric heater with a thermostat (the kind where you actually set the temperature) would work nicely. Another thought: a small clip-on fan attached to the top of the door (if there's room) might direct the heat downward?
Ed, Deb, and 2 dogs
Looking for a small Class C!
