Condensation inside trailer.
Muddydogs
Went camping this past weekend, temps were in the 30's with rain and snow falling and I had a lot of condensation on the windows and roof vent covers. Whats the best way to deal with the moisture inside without letting all the heat out.
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
14 REPLIES 14
slarsen
As was said earler: dehumidification, and/or venting.
Keeping the air in the trailer moving (fans) will help because the moving air keeps the exterior surfaces warmer, so less reason to form condensation.
Get a humidity gage. Have some idea of just how big your problem really is. They are cheap and easily found at Target, Walmart, lumber yards, etc.
BTW, it comes up every year: some people try to heat with propane heaters inside a trailer. The result will be lots of moisture. It isn't a good idea, just like 'ventless' fireplaces aren't a very good idea for more than occasional use. Use the furnace (combustion fumes are vented outside with the created moisture) or electric heaters.
JIMNLIN
Padlin wrote:
We started carrying a Newair 25 pint dehumidifier, obviously it's only for when we have hookups. Only down side is it gives off a decent amount of heat, which is okay when it's cold out.
We had to use two dehumidifiers for living one winter in a 5th wheel trailer with temps down to zero and 40 mph winds.....while the house was being built
The first thing we learned was forget about cracking a vent. All that did was cause a cold drafty camper and the heater running 24/7 and did nothing for our humidity problems.
Now for moderate temps and a dry climate cracking a vent may work.
My son lives in central FL. He uses several containers of Damp Rid in his 34' trailer.
Padlin
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
Lynnmor
motorcycle jack wrote:
If you don't want to open and vent, the only option is to get "Stay Dry" and use it. It is slow acting though and may not completely stop the moisture. If not then you'll have to stop breathing about 2AM ๐Ÿ™‚
If Stay Dry removes moisture, where does it put it? I think that it won't do a thing.
pugslyyy
We have a roof vent directly over the bed that we crack open at night, makes a big difference. When we cook we always have the hood fan on.
motorcycle_jack
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
RJCorazza
Not an option for boondocking, but we use a small GE dehumidifier. 30 pints on wheels, lives in the bathroom during the day (when running it really helps drying out wet towels and clothes) and gets moved into the main area at night. We still get a small amount of condensation in colder temps but not nearly as much as without the dehumidifier.
In our previous rig we would crack the overhead vent and run the fantastic fan on low. I will be installing one of these fans in our trailer soon... Very nice fan.
Us_out_West
Yup you'll have to open a vent.
With our dual-pane windows we have never seen any condensation.
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
Muddydogs
I'll try the roof vent in the bedroom next time. Some engineer that designed my toy hauler decided it would be a great idea to put a roof vent over the bed in the back but the trouble here is I never put the bed down as its not needed and if I did I would still have to climb the ladder to reach the vent. Guess they figured no one would be able to reach the roof vent standing on the floor due to the high ceiling of the toy hauler but I guess they never met a tall guy with long arms.
I just hate to let any heat out when I am running off battery's and using the heater as little as possible but all the moisture can't be good for the walls.
pugslyyy
We always leave the roof vent over the bed open a crack at night. We figure we are generating the most moisture/humidity.
army_guy1
I keep the roof vent open a crack to help with air movement. We haven't had any issues this way. Love cold weather camping.
Rick & Jana
Full timing since Oct 2005 - retired US Army Dec 2009
2018 Arctic Fox 27-5L
2014 RAM 3500 Big Horn
robsouth
Gotta ventilate to remove moisture. Just breathing creates a lot of moisture. Open vents just slightly, you will not notice heat loss.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
cyntdon2010
wipe the windows off with napkins, open windows and doors.
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
donn0128
Ventilation and dehumidifier
