BeerBrewer's avatar
BeerBrewer
Considering the Andersen Weight Distribution Hitch
I am considering purchasing Andersen's Weight Distribution Hitch with my new (used) TT. I like it because it is light weight, simple to hook-up and unhook and it's supposed to provide weight distribution and remove bounce and sway.
Those of you that have owned/used the Andersen hitch did it work well for you? Meaning did it transfer enough wt forward, did it remove/reduce the sway, did it remove bounce, did it hold up?
I've read so much conflicting info on the hitch. I've read people complaining that it doesn't really distribute enough weight forward, that it didn't hold up well. I've also read that its better for lighter trailers, some said its better for heavy. I'm just confused!
I'm close to picking out a small lite TT (our first) and I'm definitely planning upon using a anti-sway WDH with it. As you know some WDHs can be quite heavy and that could impact the TT I buy because my truck only can handle 700 lbs of tongue wt.
Thanks
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
