mpfireman's avatar
mpfireman
DEF in diesel SCR systems.
Modern diesel engines require the use of DEF fluid to meet the clean air standards. I tow with a 98.6 Dodge Cummins powered truck, thus no DEF is necessary. But those who have the newer versions of Diesel engines, I think after 2006 or 2007 need this DEF fluid. Reading the April 2016 issue of Trailer Life, there is an issue on the limited life of this DEF fluid. This fluid can degrade over time and is less effective, and may even cause trouble codes to illuminate your CHECK ENGINE light. The approximate shelf life is 36 months at 50 degrees F
18 months at 77 degrees F
12 Months at 86 degrees F
6 Months at 95 Degrees F
2 Months at 104 Degrees
Side note, DEF fluid will freeze at 12 Degrees F
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
