wbwood's avatar
wbwood
Different steep driveway question
Most questions ever asked on here about steep driveways, have to do with the driveway sloping from the house to the street. We actually have the opposite problem. When we had our TT stored at home, we had it stored on the side of the house in the yard. It was always a pain in the but pulling it out. We would have to watch the weather and pull it out early if it looked like the ground might get wet. We had to use the 4 wheel drive to pull out the heavy TT due to the slick grass. I know if we had a hard packed gravel drive or paved drive, that it would of been easier and better. But I always wondered about the slope of it. Not sure if they could get the actual parking pad of it level or not. We never plugged the camper in or used the fridge until we pulled it out to the road. With lowering the tongue all the way down, it was a little out of level. I think if I could get the wheels raised 5 or 6 inched, that it would of been a big help.
The other day, I was in Autozone and saw these ramps. I wonder if using a set of them on the TT wheels would of worked.
What do you think? What about on somethign like a Class C in case we get one? I know I would need two sets of them due to dual wheels. They are rated at 16,000 lbs and a Class C would be in the 14,000 lb range. Of course our TT was a bit less than that.
So what do you think? Any suggestions for a parking pad on the side of the house on a slope? It may be somethign we might do anyways to get the the pop up and utility trailer out of the driveway anyway. Would hard pack gravel give enough traction, over say grass?
