rbp111
Oct 23, 2017Explorer
It is easy to refill. All you have to do is chill the small container, or put it in the freezer. Then when you refill the container, you put the adaptor on the container and then you turn the larger container, the one having the gas to refill the small container, over. You open the valve and hear the gas going from the larger container into the small one. When the noise stops, you close the valve. Disconnect and you have it refilled.
Like it was said before, you don't fill it all the way, about 3/4 or there abouts. The adaptor is not cheap, but it sure does pay for itself after filling up the small containers.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 25, 2025
