- RinconVTRExplorer
obgraham wrote:
But nobody has answered my question: what actually happens to the propane canister when it goes into a specific recycle bin, or when it is picked out of the usual recycle line?
I not only answered, but I answered with specifics AND pictures.
When the bottles are picked out or recycled properly, they are evacuated and recycled as any other steel is. They are NEVER reused or refilled. - fyrflieExplorer III
CavemanCharlie wrote:
mileshuff wrote:
skipro wrote:
I refill them and use them again.
On the side of the bottle is a warning not to refill.
Do you have some sort of adapter to refill them from a larger tank?
They make adapters and sell them on the internet. There are also a bunch of videos on how to do it. You do not get them very full unless you remove the relief valve on the container.
I have never done it. I just heard about it. I don't think that you can legally transport them if they are refilled.
Nothing magical happens to the cylinder when you refill them except they aren’t as full as a new cylinder. ( my experience)
The do not refill warning is two fold. Increase profits and to cover their arse should a cylinder fail. - fyrflieExplorer III
SoundGuy wrote:
Here in Ontario we're asked to recycle propane canisters in orange bins located in each provincial park, operated by Stewardship Ontario. Hard to believe there aren't similar programs in the US. :h
There are. - 2112Explorer IISteps I take to refill
Wrap a damp towel around small bottle and place in the freezer for an hour.
With large bottle valve closed place adapter on large bottle and turn upside down.
Screw small bottle onto adapter and open valve. Check for leaks.
Leave attached with valve open and frozen towel on bottle for 1 minute.
TURN VALVE OFF and remove SMALL BOTTLE from ADAPTER.
Repeat - rbp111ExplorerIt is easy to refill. All you have to do is chill the small container, or put it in the freezer. Then when you refill the container, you put the adaptor on the container and then you turn the larger container, the one having the gas to refill the small container, over. You open the valve and hear the gas going from the larger container into the small one. When the noise stops, you close the valve. Disconnect and you have it refilled.
Like it was said before, you don't fill it all the way, about 3/4 or there abouts. The adaptor is not cheap, but it sure does pay for itself after filling up the small containers. - tinner12002Explorer
I've also thought about doing that! Looks pretty easy. - CavemanCharlieExplorer III
I have never done it. I just heard about it. I don't think that you can legally transport them if they are refilled. - mileshuffExplorer
Do you have some sort of adapter to refill them from a larger tank? - tenbearExplorerHere in Vermont we return the empty containers to the dealer for recycleing.
- Edd505Explorer
me too
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
