Apr-19-2013 04:35 PM
May-09-2013 02:14 PM
May-09-2013 01:28 PM
Ex-Tech wrote:
Just received this notice from Dometic today at my dealership.
The recall is for the electric motor used on OEM awnings installed from the factory.
If your coach was produced between February 13, 2013, serial #305xxxxxx through April 9, 2013, serial #314xxxxxx and has a Dometic power awning, you may want to check with Dometic.
The issue is that the awning could deploy either standing still or while driving.
This recall may also apply if you had your awning motor replaced around the same time.
Call 1-888-943-4908 for information.
Apr-20-2013 01:47 PM
If your coach was produced between February 13, 3013, serial #305xxxxxx through April 9, 2013, serial #314xxxxxx and has a Dometic power awning, you may want to check with Dometic.
Feb. 13,3013????
Apr-20-2013 03:25 AM
Apr-20-2013 01:59 AM
