thcguy12's avatar
thcguy12
Eaz Lift R3 vs Eazy Lift TR3 -- which to buy?
Need your help deciding on a weight hitch with sway control!!!
Eaz Lift R3 vs Eaz Lift TR3 -- which to buy?
They both seem to have sway control turned on my a allen wrench and brake pad system. R3 uses top loading bars and the TR3 seems to use straight bars (that you do NOT have to raise camper and tow vehicle up to push in.
TR3 max weight is 600lb tounge and 6000lb max weight.
R3 is the same.
Camper Specs
2700lbs dry - travel trailer
4750 max weight / average probably closer to 3500-4000lbs
Estimated tounge weight is between 400 to 500lbs.
Towing with small SUV -- 08 GMC Envoy
with 5200lb tow capacity.
No RepliesBe the first to reply
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
