We own a 2006 Fleedwood Bounder 32w on a ford chassis. Some of our 120v electric outlets are not working either on shore power or generator. Found only one ground fault breaker and tried all the break...
Probably a hidden GFI. You may be able to make a pretty good guess where the problem might be by looking at where the non working outlets are located and see where the shortest path to the power panel is. The missing GFI or loose wire should be along this path.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
