justiceb133's avatar
justiceb133
Enclosed Car Hauler With Elongated Tongue
I am looking for an 8.5' X 20' enclosed car hauler with an elongated tongue. Anyone know a dealer in North Texas or Oklahoma that keeps these trailers in stock? I want one with a 60" plus tongue. I would be pulling it behind a 40' motor home diesel pusher. Any advice on a trailer or dealer? Thanks!
  • Flat front for me.
    I have a big Haulmark trailer that I found on Craigslist. The tongue on it is over 48" but I can't remember the exact length. 52" rings a bell.
    I've used a V-nose trailer for non RV trips, and I honestly hate the V nose space in the front of the trailer. I can't pack totes in a logical arrangement in the angular space. I HATE IT.
    I've heard of people with V-front trailer behind a class A or Class C, and they hated it. Something about how the air flows around behind the coach, a V front trailer creates weird turbulence and affects how the trailer travels down the road.
    I V-front works great for less wind resistance behind a regular truck, but it does nothing in that regard for a tall truck and camper (like I have) or towed behind a Class C or DP CLass A
  • I do have to take right hand corners a little wider because of the 18" tongue extension.That's why I questioned the 60" and having to make even wider turns. If I didn't have the 18" extension, I think the trailer would follow the same turning path as the MH.
    My trailer has a shallow 18" V-nose. I think that is why the dealer recommended the 18" extension. With a flat nose, I don't think it would have been a concern. The actual length of my tongue from the point of the V, to the end of the coupler is 40".
    I hope this info helps.
  • Thanks for your help everyone! I appreciate it very much. The 60" is really the standard 48" tongue plus 12" The standard tongue plus 18" I have been told is another option. Glad to hear they are working for you. Are your trailers flat or V fronts?
  • I know Wells Cargo / Haulmark (both owned by Universal Trailers) will build a trailer with an extended tongue. The dealer I have dealt with say there's the option during the order process.
  • I have a 22' Haulmark trailer with a 18" extended tongue over the standard length. I tow it behind a 40' motorhome and even on the sharpest turns, it never even comes close to making contact with the trailer.
    A Haulmark dealer in your area should have one in stock or be able to get one from another dealer out of the area.
    Curious as to why you want such a long tongue extension?
  • I had one custom made. The manufacturer didn't want to extend the tongue. I should've gotten a 20' box put on a 22'-24' frame.
    Get one in all aluminum for weight savings.
