eternabond
Wolfman28
I was wondering if the eternabond tape should go over the trim or under the trim. Looks like previous owner hit a tree and the roof is needing repaired on the edge.
4 REPLIES 4
bobsallyh
Over the trim, you are trying to stop leakage. If someone doesn't like the look, ask them which they would rather have, looks or delamination.
MrWizard
Moderator
Moderator
i put it over the trim
i don't put screw holes thru the EB, if i don't have too
I can explain it to you.
1997 F53 Bounder 36s
1492
Moderator
Moderator
opnspaces
Navigator II
Navigator II
Protection wise it's better over the trim. Aesthetics wise it's better under the trim which means you have to screw poking through the Eternabond.
