willald
Jul 17, 2013Explorer II
truenorth50 wrote:
I took and applied all the good advice posted here and went one step further. I had two 20" pieces of two inch angle iron welded ( with the point up) to the dolly, to form a physical obstruction to prevent the tires from rolling. Coupled with the straps and chains, I have managed to eliminate the tire movement altogether. The angle iron forms an 'indentation' that the tire sits in and 'voilà !' the problem is gone.
Hey, not a bad idea, I like it. When you get back home, any chance you might post some pictures on here of what you did?
Will
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
