MacManOne
Aug 15, 2014Explorer
Sorry for the delay reporting back. My solution was the brute force method.
Note that my problem was arms NOT EXTENDING. They were frozen in the RETRACTED position. This is an extreme case. I don't ever plan to retract them. They'll stay extended unless I send them in for a rebuild.
* Removed the square rubber caps at the base of the arms.
* Liberally soaked the rods with WD40
* Used an aluminum rod (so it would be softer than the steel of the towbar).
* With a 5 lb sledge hammer I drove the towbar arms out until they locked in place.
Of course this made it difficult to jockey the car so that the towbar could be attached. No, I don't recommend this, but it worked for me.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
