โSep-03-2017 11:57 AM
โSep-06-2017 06:42 PM
brianosaur wrote:Grit dog wrote:
Need to know more so, what year van. Engine, trans, rear gears?
All I know is its a 2006 4.6L V8 with 87k miles on it.
...where would I find the other info you requested?
โSep-05-2017 05:29 PM
โSep-04-2017 07:55 PM
brianosaur wrote:
I also have a Ford e250 van. These are the specs:
GVWR ........... 8600
Curb Wt......... 5336
GVW............. 6336?**
Max Payload..... 3264
Towing Cap...... 6600
GCWR............ 12000
GAWR f ......... 3800
GAWR r ......... 5520
Rear Tire load . 3042ea
**Guessing TV may have 1000 lbs in passenger and cargo.
โSep-04-2017 10:55 AM
โSep-04-2017 09:45 AM
brianosaur wrote:
So I've been doing researching like mad and trying to figure all my weight limits before we purchase our first TT. We are headed to Hershey in two weeks, to their big RV show, and I want to be as prepared as possible. After much reading, I am very cautious about being the highway ahole that overloads his vehicle and puts his family, and others on the road, in danger.
We were going get something in the small ultra light class to tow with our Honda Pilot, and then I figured I should just get my second TT now and just skip the tiny one I'd probably sell in two years anyway.
GVWR ........... 8600A good rating to have on your list and you will need the trailers GVWR too
Curb Wt......... 5336Useless, unless you have a stripper model with no options, except for the tow option and this is the "dry" weight of the trailer, but it will also come with a tongue weight number (typically 10% in order to get the highest tow weight for any TV) and is a good indicator of how or the potential of how well the trailer will handle....best to have tongue weight in the +12%-15% of the trailers ACTUAL weight
GVW............. 6336?**you will need this and load up your TV as if going to tow. Full up with people, pets, cargo, luggage, etc and go out and weigh it
Max Payload..... 3264A good starting point, as this is the weight as shipped WITH options...but does NOT have the stuff you will load into/onto your TV. Subtract this from the GVWR and it will be more than the listed towing cap (MTWR...max tow weight rating)
Towing Cap...... 6600see Max Payload comment
GCWR............ 12000a very good number to have and will be the basis for the simple math to figure your "true" MTWR
GAWR f ......... 3800A good number to have on your list
GAWR r ......... 5520A very good number to have on your list and most limiting of all the other RATINGS
Rear Tire load . 3042eaDitto above RGAWR
I currently only have a step bumper hitch on the van (500lb TW) but will be installing a new Class III/IV hitch to accommodate as needed TW.
**Guessing TV may have 1000 lbs in passenger and cargo.Until you load and actually weigh it fully loaded ready to tow...in guessing game
I have done a few online calculators but get different numbers from different sites.
So, what TT GVWR should I top out at to be safe?Weigh your TV fully loaded ready to go towing and subtract that from the GCWR of your TV and that will tell you the true TT GVW (it's actual weight your TV is now rated to tow
โSep-04-2017 08:32 AM
โSep-03-2017 06:18 PM
brianosaur wrote:bikendan wrote:
In addition to the hitch receiver, you'll need to duplicate the whole factory tow package.
Wiring for brake controller and transmission cooler.
Then install brake controller.
Think the TC is absolutely necessary?
โSep-03-2017 03:42 PM
โSep-03-2017 03:05 PM
โSep-03-2017 02:26 PM
โSep-03-2017 01:46 PM
wanderingaimlessly wrote:
Try to find a TT with a loaded weight under 6000 and have a blast.
You said nothing on family size and weights but if we start with a typical family of 4, 550-700lbs will cover most (not all) scenarios. Adjust as needed for your situation. Add for tongue weight 900lbs to be safe, another 125 for the hitch, and you have a total of
1725lbs, again well within the vans limits.
โSep-03-2017 01:24 PM
โSep-03-2017 12:23 PM
โSep-03-2017 12:15 PM
