VE3ESN's avatar
VE3ESN
Geo method in very hot weather
We've successfully used the Geo method (Calgon, detergent, and occasionally Javex) and it's worked well, but this summer has had much longer periods of very high temperatures. Fortunately, there's been no odor inside the Roadtrek, but occasionally the outside smell coming from the vent pipe has been overwhelming :E (One minor problem regarding Calgon is that it's not available in Canada any longer, and I haven't been able to find a suitable replacement, but that's another issue!)
I recently flushed out the vent pipe to see if it was clear, which it was. We use our Roadtrek for day trips and longer trips, mainly boondocking, and can't always easily get to a dump station.
Do you think that the outside smell is due to limitations of the Geo method in very hot weather? I saw an ad for "Happy Camper" holding tank treatment which apparently works well in extreme heat conditions, but I want to make sure that the horrible outside smell will be eliminated or at least reduced. Or do you think that a vent cap such as the "360 Siphon" would help? Our Roadtrek has no cap at all on the vent pipe.
All suggestions will be greatly appreciated.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
