Uncutbulldog's avatar
Uncutbulldog
Getting 2014 Ford Fiesta SE Hatchbach (manual) Tow Ready
I decided to start a new thread because I just bought a new toad. I want to get it ready to tow. I want the lights and braking to be a permanent solution. I want to be able to "plug-in" and go.
So far I bought the following 2 things (uninstalled):
Blue Ox base plate: BX2622
Roadmaster Universal Hy-Power Diode Wiring Kit RM-154
I am looking at using the "Roadmaster InvisiBrake Supplemental Braking System."
My 2015 Sunseeker 3170ds has a 7pin plug-in on the back.
If I take all of these items to my ford dealership, can they install them all and just have one plug-in at the front of my Fiesta?
I want simple and quick every time we hit the road.
Thanks Guys!
2015 ForestRiver Sunseeker 3170ds:
Dry weight: 12,378
GCWR: 22,000 lbs
GVWR: 14,500 lbs
Engine: Ford 6.8L V10 E450
Hitch rating :7.5k/750
2014 Ford Fiesta SE Hatchback:
Weight: 2520 lbs
  • I have 2013 focus the front is held on by six screws.Check with a body shop. I like the blue ox base plate not a lot showing when not towing.
  • Uncutbulldog wrote:
    I plan on using this tow bar. I believe it just folds up and I can store it in an outside storage compartment.
    Blue Ox Aladdin Tow Bar - 7,500 lbs
    The Blue Ox Aladdin tow bar folds up off to the side and can remain on the hitch while stored. There is a cover available.
    Consider the integral Blue Ox AutoStop surge braking system instead of the InvisiBrake. http://blueox.com/p-1553-autostop-for-aladdin-alpha.aspx
    I used the Blue Ox BX8869 bulb and wiring kit.
    Blue Ox Aladdin tow bar and AutoStop for $871:
    http://www.pplmotorhomes.com/parts/towing/tow-bars/blue-ox/alladin-tow-bar.htm?utm_source=google&utm_medium=partsshopping&utm_campaign=partsfeed&gclid=CIDD-8v2rb0CFYsWMgod9jcA8A
    http://www.hitchsource.com/blue-ox-autostop-for-aladdin-and-alpha-towbars-p-35037.html?gclid=CLO_taL3rb0CFcg7MgodvSsAqQ
  • The Fiesta front end will have to come off to install the baseplate, so you are looking at 3-4 hrs for install. I doubt if a Ford dealer would install any of those items, plus,I wouldn't let them do it anyway. Find someplace that does it as part of their business.
  • If you bought the baseplate and the other stuff at a RV dealer, have them install it. If you don't "trust "them, ask around other RVers for a shop THEY trust. Any "good" auto body shop should be able to do the job too...my advise is to stay away from any "dealer"...anything off the "beaten path" for these guys ("genuine Ford parts, etc) they simply......well, I wouldn't do it.
    To my knowledge you will not void any warranty by installing a baseplate or a diode kit. g'luck!
  • I plan on using this tow bar. I believe it just folds up and I can store it in an outside storage compartment.
    I know this is overkill but you never know what the future holds.
    Dry weight: 12,378
    GCWR: 22,000 lbs
    GVWR: 14,500 lbs
    Weight: 2520 lbs
  • Any body shop/car repair shop can install the items at a labor rate much cheaper than your dealer. If you look up the baseplate at Blueox it should give an indication of how difficult the install is. Usually 1-2 hours labor if the front end does not have to come off. When you buy the tow bar, your choice will be attached to either the MH or Car when not connected. I prefer attached to the mh.
    Good luck
  • I should also mention that I "have" to use a dealer so I do not void any warranties.
    Dry weight: 12,378
    GCWR: 22,000 lbs
    GVWR: 14,500 lbs
    Weight: 2520 lbs
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
