toneyp wrote:
Just traded to new pickup. Was disappointed to find out that now you have to disconn battery to tow after last 5 years of shift transaxle to neutral, put in park, lock doors, get out and go. Anyone suing a remote battery disconnect to keep from having to go under hood every time? If so, what kind?
toneyp,
You are not the only one here with thoughts of that issue. Many are not happy about it but, unless GM has some sort of retrofit system (that is if they were even thinking about it) I guess all the owners of the '15s and newer (I think this "disconnect thing" started with the '15s, not sure)will have to deal with disconnecting the negative cable if and when, they plan on towing it.
Now, with all that being said, if it were me that had to deal with this issue, one of the first ways I'd look at handling it would be to purchase and install, one of these:
Battery Disconnect SwitchI've installed these before and, they're quite simple to install. And, all that's needed to be done is, re-route the battery negative cable to one side and, put a new cable from the switch to the negative post on the battery. Done!
I doubt you'll "fry" any alternators or, do any damage to any portion of your electrical system. I kind-a suspect GM knows what they're doing when they set up a system like yours and many others. The really good part about using that type of switch is, the red key is removable and, that makes for a great theft deterrent of your vehicle.
Scott
