Beentherefixedt's avatar
Nov 19, 2018
Go For It! Repair or Replace it Yourself..You Can Do It
Consider this post a "Call to Arms" so to speak to encourage anyone to undertake their own RV repairs, modifications and maintenance. I read so many posts here asking if this or that can be taken on by the owner. In most cases it can be with no problem.
Of course I realize that due to age or physical limitations some may not be able to do this. But it doesnt hurt to educate yourself as much as possible to avoid being taken advantage of by RV dealers and repair facilities.
Anyone can do just about anything to their own RV.
There are two electrical systems 12 volt DC and 120 Volt AC.
There is a propane system for the stove, Furnace and the water heater (most units)
Then there is the plumbing system with Two systems interior to that, the onboard system using the water pump and fresh water tank and the outside supply.
These systems are very basic in most cases and familiar to many of us from our houses. Those that may be unfamiliar are still not complicated and can be mastered with reading the manual and doing some minimal online research.
In my case I have done the following on my 34 foot Gulfstream trailer.
Installed all new flooring incl. "floating type" in the bathroom and entry.
Replaced Kitchen sink with larger better (standard household models) SST double sink and faucet
Tore out my bathroom vanity, sink etc and replaced with a new one, Tiled the backsplash and counter and new medicine cabinet/mirror.
Re-wired my pigtail, getting rid of those horrible plastic twist nuts and terminated each wire with ring lugs (marine type with heat shrink), installed a distribution box and power dist. strip.
Replaced the old corroded inline 50 amp fuse in the pigtail with a marine grade 50 amp fuse and water resistant box.
Cut my Power cord off (I had the type that had to be pushed in and out) Added a marine grade Marinco receptacle mounted in a weather proof box wired to a dist. box in my bathroom and installed a new plug on the end of my cord...freeing my cord and making hookup much easier, surer and safer.
Repaired and adjusted my main living area slide
Tore out the living area dinette and sofa, moved some interior storage areas, created a table and chair dining table area and added to recliners essentially reversing the floorplan of the original.
Put down all new commercial grade carpeting in my main slide and living area.
Removed and recovered all of the window surrounds in the main living area.
Replaced both 12 v and 120AC light fixtures in the main living area.
Tore out the upper bunk of my small slide area and added matching cabinets I bought from Home Depot above the lower bunk.
Insulated the complete underside of the trailer as well as all outside storage areas with Owens Corning Pink Foamular insulation covered over with White Plastic version of that commonly used under most RV's.
Removed my Furnace cleaned and re mounted it properly. (It was not installed correctly at the factory so that much of the air didnt make it into the duct system.)
And the biggest job of all...I found some old rot in the floor of my small slide (I bought this trailer used) It was all dry rot. I replaced the slide floor and fit in new framing where necessary. This entailed removing the outside skin and replacing removing the old floor and replacing.
Now none of these were done in a garage and only the slide repair was done at my house. All else has been done on the road.
So you too can do this stuff. HOnestly...give it a try
