Intrepid_Family's avatar
Jun 01, 2017
Awning Help!! Replace or repair?
We've got broken brackets on our camper awning. Two months ago, we had a bad tire blow-out that caused a bent axle, major repairs, etc., and we wonder if the brackets cracked/broke during the bouncy ride before we realized the axle was in trouble. We haven't had the awning out since it was in the shop to be repaired. This weekend, we rolled it out to scrub/dry it, etc., in preparation for a trip we are taking in 2 weeks.
The awning itself, spring mechanism, etc., is fine. The rear bracket assembly is fine, but the front one is cracked at the bottom and completely broken through at the top, so that the top support arm no longer affixes to the camper.
We are in trouble. I don't want/like to camp without it. One nearby repair place can't even look at us until mid-July. We took it to a dealership further away who could look at it today -
and they tell us they don't make the brackets anymore, so the only thing to do is to replace the entire awning!
For $2,000!!!
Is this right? It just seems very fishy to me! The awning is 26 foot with no holes or tears, and the spring mechanism is still tight and functional - we were able to pull it out and put it back up this weekend without problems. We just couldn't *lift* it because of the broken bracket. Does this sound reasonable? Even the actual support arms are undamaged. They are white metal (?aluminum?) and the brackets are a heavier gray metal - it's the gray bits that have cracked/broken. The actual arms are completely normal/functional
I'm just wanting to make sure we're not being taken in out of our desperation.
Would it not be possible to replace the entire support-arm set-up on the broken side? That seems like it ought to be less expensive than replacing the whole thing. Are they that brand-specific and proprietary that if one piece is broken it has to be entirely replaced?
The RV is a 2007, but we had rain damage in 2010 and the entire awning was brand new at that time.
If nothing else, we would like advice as to how we can "jerry rig" this for a while - maybe even get us through the summer - without having to put in a brand new awning! We're in a very serious bind because we have a trip planned in mid June that is not optional and cannot be changed or postponed. The RV is our "hotel" - we can't possibly afford to house all of us in an actual hotel. If we have to go awning-less, we will, but I'd rather find a quick and effective solution.
Anyone? Please!
