Jul-24-2018 07:58 AM
Jul-29-2018 03:17 PM
Jul-27-2018 12:46 PM
rhetthughes wrote:
Thank you all for the advice! I’ve started by calling Dometic. They want me to send pictures to see if it is an issue on their end or the camper manufacturer (basically said that the panels are often installed at the rv factory to match the decor, and not something that dometic does. So could definitely be a faulty installation at the rv factory.
Jul-27-2018 05:34 AM
Jul-24-2018 02:54 PM
Jul-24-2018 12:00 PM
BurbMan wrote:
There is supposed to be a trim piece ob the bottom of the door that holds the panel in place. I would call Dometic and see if you can fix the problem right before you glue it in there permanently....because you know that once you do that you'll need to take that panel out....
Jul-24-2018 11:56 AM
SoundGuy wrote:2DHoop wrote:
Hello, will you need to be able to remove this panel at any point in the future?rhetthughes wrote:
I can’t imagine ever needing to. It’s just reall decorative - that black panel on the standard camper fridge.Chum lee wrote:
If you ever have to replace the old fridge in it's entirety, you may have to transfer the existing panel on the old fridge to the new fridge if you want it to match so don't make it too difficult to get off.
To the OP - this is correct. Apply GOOP to the back of the panel, a few dabs along the top edge and a few along the bottom edge, where you can later break through it with a thin, flat wall scraper if need be. Support the panel in position for a day while the GOOP cures, then it should hold securely.
Jul-24-2018 11:26 AM
Jul-24-2018 11:08 AM
Jul-24-2018 10:47 AM
Jul-24-2018 10:46 AM
Jul-24-2018 10:13 AM
Jul-24-2018 09:37 AM
Jul-24-2018 09:26 AM
Jul-24-2018 08:50 AM
